the modem was detected,but at the end it says no drivers found and hardware wont work properly
1. Windows will search for the modem's usb drivers in its cache etc.
2. If not found, Will ask you give another location.
3. If you have the BSNL CD insert it and select.
4.If you have downloaded the drivers from the Web give location where you saved it. If ZIp files you shoud have decompressed the files. Example C:/zxdsl usb / drivers.
Then in TCP/IP usb port details will appear.
Para two : If computer is otherwise normal ,and you are using Dialup,
No need to reinstall Windows XP/Sp2.
Try this
Start RUN type cmd Type sfc /scannow. keep XP disc ready.
It will take at least an hour to verify the integrity fo the files.
Para three : can you change the RJ45 cable ? or insert the other way.
I mean the end which was connected to modem goes to computer and
visa versa.
Para four: as @ajayap has said , somehow Modem pages to be accessed.
By the way you have System Restore ? Any Date before the lightning day, when you dismantled the set up ? when all was OK.
Para five : On dialup check your usage with 14digit portal ID and password. ( do not change your User ID password ).
Check in webmail, whether you can access your email acct . Just to confirm PW are OK.
All said and done, access the Modem !!!!
Try this
visa versa.
