Limited or No Connectivity. Pls Help
Hi guys,I got my new modem from BSNL today.But unfortunately,i left my ethernet cable in my cousin's home,so couldnt connect it..They didnt brought a new cable for my modem too!!! Anyway,i have my USB cable and am trying to get a driver...I downloaded the one ONLYTEST gave me here.But its not working..Anyone have the USB driver for my ZTE ZXDSL 831AII modem?
I did got the ethernet cable and i connected it. Still the same old problem.Limited or No Connectivity. The modem is perfectly new and all the lights are glowing and is static and I cant still get connected to.. Limited or No Connectivity.I tried to put in the ipconfig as u said, but still no connection..
I am having DataOne Broadband internet BSNL connection . I am using Smart AX MT 841 Type IV modem which is 2 years old, about 2 months back my connection was getting disconnected frequently and SNR value UP/DOWN was very low at .8/27, after some change of cable by BSNL this value came up to 16 /27 and it was working fine for the last 2 months but now again the same problem has reappeared but disconnection is not so frequent,the SNR Value is 2.8/27, on complaint to bsnl they said their cable was not faulty and JTO brought another modem and checked my connection with his modem and he found SNR value UP/DOWN at 25/27, and declared my modem to be faulty . After Default Reset of modem and change of value in PVC 0 TO 0/35 , and resetting of user id and password the value comes up to 14/27 but soon after the connection gets disconnected and automatically comes back with in a minute or so but SNR up/down value again drops to 2.7/27 .Modem is functional except some disconnections sometimes and file transfer is taking very long. I want to know if any one can tell me the following :- A . What really is gone wrong or what is this problem like,has any one come across this problem? B. what is the further remedial action ? C. In case i have to change the modem,if performance drops further ,which is the best modem available in the market compatible with BSNL coonection and in what respect is that superior to BSNL modems and approximate cost. Thanking you in advance.
@jasCheck the modulation usually adsl2 or G dmt. Enbale bitswap ( explanation not needed /not known to me !)Please check the splitter and RJ11 cables for corrosion /oxidisation.Report attn data also along with SNR .
@jas
@essbebe G.Dmt.BisPlus,snr 2.8/27.5, attenuation 2.0/25.5,new cable from telephone pole to right upto my PC changed today,all connections checked for corrosion/oxidation, even by passed splitter by connecting cable direclty to check performance but no improvement . Took the modem to SDE/JTO office and checked performance on thier PC, SNR value was 22.5/28.5,kindly advice. Enabelbit swap,not understood/known ???
/members/jas/
1.How was the Modem tested in BSNL office ? with connection to Ethernet port from Modem or in Wireless Mode ? Disable wireless mode and try.
2.Any chance the Splitter is damaged recently due to lightning/electrical/electronic radiations (/microwave oven etc ). Ensure ALL phones ( including Cordless Base are connected after the splitter .
3.Do not connect modem direct to Telephone line, in future.
4. Bitswap "enabled" sometime helps.
5. Please post ipconfig/all data.
For reference : ( web site with screen shots )
New Page 1
SmartAX MT-841 ADSL MODEM (Type-IV) MENU
@essbebe 1. Modem was tested with Ethernet port connection, tried with wireless disabled but results are same 2. Splitter is in good condition same results are coming when bypassing splitter and connecting directly to telephone line [only for short duration ,for test purpose only] telephone line is clear . Phone is connected after splitter only . 3. Splitter is in use all the time just to check this problem modem was connected directly . 4 Bit swap ''enabled'' still same results 5.IP was ''obtain an ip address automatically '' but after this problem changed to IP: 192.168.1.100 Subnet:250.250.250.0 Gateway: 192.168.1.1 DNS 192.168.1.1 Alternate DSN 61.1.96.71,I have tried with other DNS servers as given in this forum but results are same . After Default Reset or any changes like Bitswap enable or wireless disabled and save of settings ,or change of value in PVC 0 TO 0/35 , and resetting of user id and password, the SNR value comes up to 13-14/27 but soon after the connection gets disconnected and automatically comes back with in a minute or so but SNR up/down value again drops to 2.7/27 .Thanks anyway so nice of you to spare your valuable time. God bless u
