Sorry for late.
you posted your ip config results in earlier post, they shows ip address of 192.168.1.1.
do one more thing:
1. go to network connections
2. delete your dial up connection if u have any.
3. right click on local area network and click properties.
4. in the general tab, scroll down to the list and select internet protocol (TCP/IP) and click on properties button.
5. in the properties window, in general tab select obtain ip address automatically radio button.
6. on alternet configuration tab make sure automatic private ip address radio button is selected.
7. click on ok, again click on ok.
8. now follow the procedure which i mentioned in my previous post.
9.reply the results. ok.
i am giving you the report of my ipconfig/all below:
Ehternet adapter Local Area Conneciton:
DHCP enabled-------------yes
Autoconfiguration enabled------------yes
autoconfiguration ip address------------169.254.252.*
subnetmask----------------------------255.255.0.0
PPP adapter Broadband connection:
DHCP enabled---------------------------- No
IP address-----------------------------117.197.0.151 (Dynamically changes every time u connect)
Subnet
mask--------------------------255.255.255.255
Default gateway-----------------------117.197.0.151
DNS Server-----------------------------218.248.248.46 & 218.248.255.146
NetBIOS over Tcpip-----------------------Disabled.
Thats it. u see i have different ip address for my lan card and for dial up connection. lan ip remain same all the times, but the dial up connections ip address changes dynamically whenever u connect.
do the above steps and then follow the instructions from my previous post.
if u have made any other changes then first undo them, bec they may do some kind of intruption. ok
Sorry for late.
do one more thing:
Subnet mask--------------------------255.255.255.255
oh i just read the last post of yours that ur DSL light always blinking.
in order to connect to the net DSL light should be constant.
do u have th phone number of the person who installed the modem in your house, if yes then call him about it. if not then report about DSL light on your local exchange, bec without DSL constant light u will not be able to connect at all. don't reset the modem if u r not able to go in to the modem settings. bec if u do reset then how u set new settings without entering in the modem settings.
ok
after the DSL light remain constant then u should follow my instructions first follow 2nd post then follow second first post. ok
