Yes you can set it up using the
tablet. I used the tablet to set it up fot the first time. I once again would like to reiterate the the modem is os independent.
can any one plz tell..
I dont have pc.. Can i set it up and use from my
android tablet...?
Hey hi,
I am still looking the aspect of buying the product that you have mentioned, the only issue that is concerning me is the heating problem. I am not sure if it does have a heating issue with it. Cause the only reason i am not able to buy is that i am not sure if this device like the previous one of mind from another brand, got heated up so much that i couldn't keep it in my bad as well. So if you can help me by telling that if the device do gets heated up, and to how much extent ( this you can tell by rating the heating level on a scale of 10) and that to after how long usage does it heat up.
Boss all devices heat up in use. This is no exception. I keep it plugged and use it the entire day. It works fine. It does heat up but that's okay.
Your reply would be really helpful.
Thanks, and great day ahead.
The device gets heated up and this is normal for all devices that have cellphone type battery. I have used the micromax mmx 400r till the end of its charged capacity. It does not heat up unusually. During charging too it does heat up but not unusually too.
