Micromax MMX 400R MiFi Router Review and INSTALLATION .
Hi All, i will be buying it shortly. i would like to ask the content of the package?how do we charge it? does it come with power adapter for charging or we have to do it only via laptop through USB?does USB cable come with it?
Hi All,
It comes with a charger. There is a usb cable along with the modem.
Hi Can ANy one help in setting it up with Ipad 2 or any tablet.
I am looking for step by step.
after inserting sim and power the device on , what i need to do and what else i require other then tablet?
Do I need WIFI before hand to access Micromax set up?
You dont require anything else apart from the tablet. I had configured the modem on the tablet. It the computer is wifi then it is better, since the manual can only be downloaded/viewed using internet explorer browser.
My modem looses its wifi connection when idle for some time. i have to stay connected to keep the wifi on. i cannot use it as a normal wifi router which always available. is there any option in settings to keep wifi always on?
Just thought I would write about my experience with the MMX 400R over the last few days. It is a brilliant device. Really works well. I have not tested the range and battery life, but I don't anticipate either would be a problem. I got a vodafone connection, and had no issues whatsoever with it connecting automatically. It's got sufficient options as regards SSID, WEP/WPA etc. etc. And the device is really built sturdy. The build quality far exceeds what I expected out of Micromax!! It comes with a wall charger that has a detachable micro-usb cable (so you can charge from the mains or using a laptop), the device itself, battery. There's no microsd card, but IMHO using this device as a pen drive is something I don't ever anticipate doing. The Idea guys were really surprised that you could get a device so nice for 2400-2500 bucks considering their own MiFi device is 5000-5500.BTW regarding Idea, the showroom I went to (finding an IDEA showroom was an ordeal in itself and a long story for another time) claimed that Idea SIMs no longer work with any device other than their own datacards. Their customer care said it should be possible, but I would have to go to a showroom to verify it. Essentially all in all a third grade performance from Idea. So keep that in mind.... I went for a vodafone connection in the end.BTW the only negative point with this device is that when you connect it and open your browser and enter a site to visit, it will instead open a page on the device itself asking you whether you want to go to the Micromax Apps page. Lame, but considering it only happens once every time you connect to the WiFi connection, it's something I can live with.
Idea works with Micromax 400r mifi. I have been using it for the past three months. Yes I agree with you that the service is pathetic. The billing is not transparent and they twist the stated TRAI rules to overbill. The customer care executives are arrogant and argumentative. Besides they have no prepaid plans. The speed is good though. Please write your experience about Vodafone. I would be following the thread.
There is something I wanted to share with all my friends using Micromax MMX 400R. I purchased an MTNL mumbai-3g sim. Once activated I selected the profile and put the settings. The speed test results MTNL:300 kbps and Idea 400kbps. The difference is about 25 percent. I was able to watch youtube without buffering using the MTNL 3g service. The signal strength is MTNL: 40% and Idea:40%. Therefore I vote in favor of MTNL as the service has transparency. I never had any billing issues with the mtnl broadband connection. With idea my experience on billing was always bad. No transparency on the data download metering too. They give a very vague reply on how it happens. Well for that matter on the MTNL cus-care they have no idea about it. Still I believe in the fairness of PSU's as there is a system that checks and it doesn't run on profiteering. For people staying in Mumbai i request you to go for MTNL, give it a try. It is cheap, the sim costs Rs.101 in which 45 mb data surfing is free. Try and then recharge.
This problem is worst while using mobile phone. Because before opening any internet based application i need to open the browser and open some site and then to click on "continue with browsing" on micromax page than to close the browser and proceed with my application.
Please search for some solution for this.
^ I can imagine it's irritating. It's not such a big deal for my laptop where I only need this connection for browsing. (Just means clicking on "Don't open this page" once every time I connect). I doubt you would find a solution to this, because it's not a product that's available globally that some clever person somewhere would have figured out how to block / bypass it. (Btw why don't you just get a 3G connection for your phone?)
^(Btw why don't you just get a 3G connection for your phone?)
Actually I have a dual sim Spice Andoid phone. I use 2g sim for my business use and a temporary 3g sim for internet. But while using internet on 3g sim all incoming calls on my 2g sim gets a busy tone.
And if i take a 3g plan on my main business sim it is 4-5 time costly. (i use Rs 170/- 2gb airtel sim for 3g internet)
Hi Arvind,
I have recent bought this mifi router. I have vodafone 3g sim. activated 3g plan.
When i start router it switches on only Green light for signal which means connected to 2G.
Event in its setting page it shows 'E' which means its EDGE and not 3G.
What is the issue ? I insert sim into phone (Nokia N70) it shows 3G symbol.
Thanks in advance.
Jigar
I take your question in the order they appear.
1. The router can be connected to PC using data cable provided. I am right now writing you a reply by connecting the router to PC through data cable.
2. Yes the router can be used with all the tablets, laptops and cellphones. I have used it on Micromax funbook, samsung Galaxy tab, funbook tab, Q 80 cellphone and Sony Vaio laptop.
3. The memory card can be accessed only through the usb cable. It is not necessary for the function of the router. All you can do is store your important files in the router incase you have a memory card in the router. So you router doubles up as a pen drive. Isnt that cool. You can download from the web in the memory card only using usb, note.
4. The overview page gives you information of data uploaded and downloaded in each session. Note it will not make a log, that is once you switch off the details of the session are lost.
Note that I have come to know that there are softwares that will sit in the computer and keep a record of data usage.
On sending the manual, how do I send it to you. Is there any way I can post it on the forum??
Send me your id at arvind_prasad68,at, rediffmail.com.
Do fire your queries to make this forum lively. I will be only happy to answer it.
