Hi guys...
I stay in banglore n I got an MTNL 3G Sim from Mumbai. It took sometime 2 get it activated n somehow now it works on ma mobile n I can the "H" on ma 3G mobile n I guess HSDPA z activated.
COrrect me if am wrong.
Now from 2 days I am trying to connect using E1750 n Mobile partner on ma
laptop but no go...
I used the same default settings dat I used on ma mobile but am not able to connect.
Tried at+cgdcont=1,"ip","gprsppsmum" under Extra Initialization commands.
I have got enough balance and I can call n recieve calls.
I can go online on ma lappy using the blutooth through ma mobile.
Suggest me something.... The free Data usage left is very less n I have to test the speed before recharging wid 4500 n the stupid Tikona am using will b disconnected anytime.
Help me guys!!!!
Chinzzz
All right...!! Everything seems normal in your case...!!
So,my suggestion would be checking your modem....Try inserting other SIM in your modem and try connecting...!!..Troubleshoot your modem first...as per your symptoms
OR use your MTNL 3G SIM in any other modem and try using it in your area....and other areas....!!
What's your OS..??
Try making a new connection and delete all other connections affiliated to that modem except the new one..you made...!!
Its almost 8 MBPS now...see below..
8 MBPs now a reality... signal is 100 % now
You still in tirupathi...??
Are those speeds of Tirupathi..??
Ok, I vote for ban. Who's with me?
Is he getting Banned....???
Sorry,but can i know why...??
