Lol!Wish that was the case with everyone here...
..But seriously, doesn't living that close to a radio tower have some ill effects on health or something?
ill effects is heavy downloading lolll...
im using apn mtnl.net and also tried gprsppsdel
HELP NEEDED
MY MTNL 3G no. is still unable to connect to 3g internet.i am able to connect to connect to 2g net when i select gsm network. But on selecting 3g/umts/wcdma, network is there but on connecting it shows error 628:connection closed by the remote computer before it could be completed.Even on inserting sim in my 3g mobile
samsung Galaxy s2, i can't still connect to 3g internet. I even can't do 3g video call. I AM IN ROAMING for past 5 months and only after doing 1650 rs rechrge last week, the problem has started.my modem is fine as i crosschecked my usb data card with new sim.
error 628
you don't need a username password for mtnl 3g and the above mentioned apn's are fine.
error 628 is a subscription issue. server rejects or the port assigned to you isn't letting you connect. solution is to get mtnl service technicians reset your ports...i have had this issue quite a few times during october. they had to change my ports quite few times as i used to burn out the ports every week don't know how
so tell them its a subscription error code 628 and they would need to reset/change your existing port.
