uh, sorry for hijackthing the thread. Is there any modem+
router available that supports torrent downloading?
Supports torrent downloading? I thought as long as you have an internet connection, you can download anything..could you clarify the technical aspects of whatever you are asking?
Yes, modem router combo will not work with FTTH. Also, in the event that your device does get spoilt, you'll have to buy a combo once again. If the two (modem and router) are separate, chances of both failing together are quite limited
Oh, so if the modem gets spoilt, then yeah the router would be useless. So
Asus DSL-N10E will not be a good buy..can Sanke share his thoughts on this modem, since he has it?
Actually, I want to get rid of the Rs 50 cost per month..so you are suggesting that I buy them separately? Which?
mtnl auto refreshed the ip every six hours or so.
Too bad replacing the MTNL provided router doesn't solve the problem. Do you face the same x720? If not, what have you done to rectify the issue?
Thanks for all your help!
