@Anil Tried it. After the reboot, the ont doesn't fetch wan ip address. If wan details is not getting fetched, then how will bridge mode work?. Ont should get the wan details in the first place right?.
Isn't that what usually happens in bridge mode? The ONT would not get the WAN IP address and you'd need to configure your other router to obtain the IP address.
@varkey You are right, but what i am talking about is that when i change the GPON vlan id to 1 (default was 1510) and after the reboot, ont is not fetching wan configuration details.
That appears like expected behavior. You changed the WAN interface VLAN ID to something invalid.
Now if you are able to enable bridge mode with the right VLAN ie 1510 in this case, you should see the WAN IP address on your other router if things work correctly.
