arjunarora4212
I got banned!
how vlan will help us?? plss tell.@Kick933 Are you sure we can get vlan id out of it?
VLAN ID is needed for bridge mode to work.how vlan will help us?? plss tell.
the router is made by Team F1 which is the brand launched in India with help of D-Link@Dark_Nate
Joinis trying it's best....
Try out inspect element and get a preview of all the disabled options....
Then,we can work on it on XDA.
Does anyone know the OS of router.....Is it homebrew or is it some sort of Linux.?
Does it have usb port?
Sorry,I have never seen the ONT.
If anyone can give the inspect element,we may get few details.I hope to get VLAN I'd from it.
why don't go anydesk someone who already have jiofiber and check???@aniladivishnu.2000
Yay man...
This is what I wanted to listen.
Just like JioFi,it is sourced and have all the option.
I once tried to do the same in JioFi to u lock it and it had options to select band and all other hidden options in html.
So,I have finger crossed.
Someone just need to inspect elements properly.
Try by disabling JavaScript in browser after login.
This worked for JioFi however we could not root it yet...but VLAN id can be found.
