hy guys,I am currently on BSNL 1350 plan, 4mbps upto 20gb, after that 512kbps... i am looking to switch to youtelecome 12mbps plan, they have just started services in my building. Just need some reviews about You 12mbps plan. Do you actually get 12mbps? is it reliable? how about downtimes?Also would i need to buy a new router because they told me my dataone modem/router would not work with Youtelecom. Do they charge extra to install the router? because if i get the connection i would not buy the router right away, would test the connection for a month THEN buy the router.All input helps.Thanks !
