Need Help
anishniranam
Broadband ***** Lover
BSNL Broadband
Hi friends, Last week i have installed ubuntu in my system (Share with XP), The first two attempt failed and Successfully Completed the installation, But the Problem is While starting the system , its showing 4 OS, 3 Ubuntu and Xp.i want to remove the unwanted (uncompleted) items.Please give the instructions.
You can do it in windows.. right click on my computer in the desktop and click on properties.. you should find some "start up" option.there you will see an EDIT button which will open a NOTEPAD file.. there you can remove all the unwanted OS' by just removing that line, always keep a backup of the file just incase you mess it up!!! Sorry i couldnt give step by step instructions.. its been a long time since i used windows properly.. but hopefully this should give you an idea
Thanks for Your responce
