1. Most people tend to replace raspppoe.sys with the vista version, but if your copy of
Windows is up to date, then I would be surprised if this issue hasn't been fixed, since it's rather old. I wonder if SSV is using port binding as well as the PPPoE? If so, maybe you'd be better off getting an ethernet
router (
D-Link DIR-615 or similar) to do the PPPoE dialing for you, then you can plug in more than 1 computer at a time and surf the net simultaneously.
2. What speed you get depends on where you're downloading from and is often even affected by the time of the day. If you're downloading from outside of Fivenet's network, they have absolutely zero control over the rest of the Internet, so this can't really be helped. If you're downloading some file from the USA at midday IST, then you're competing with peak
business hours in East Asia and peak hours in the Western USA - congestion is to be expected, and (as much as it would be nice if our ISPs could fix these things) there's not much Fivenet or any other ISP can do about it.
3. This one *is* SSVs fault and should be fixed immediately. Could be bad wiring which is letting water in (and thus kind of short circuiting) or worse, one of their switches is exposed or the box that it's housed in is leaky - something like that. It might pay to find out if other users in your area are experiencing the same issues, and go from there.
Thanks, for the quick reply Mgcarley.
1. That's exactly how I am running it right now. I am letting my dual band router handle the PPPoE dialing but the thing is now I have to run my router for just 1 device. My other pc has been out of commission for sometime now. Although its a workaround for people having routers like myself, ideally I would want to plug the ethernet cable directly into my pc.People generally don't go out & buy a router just so that they can use their net connection right. I will explain the 2nd reason why-->When I use dial-up on their pc & get login error & login fails for some reason an error code/specific no. is generated which on calling SSV is asked for, but when I let my router handle PPPoE I dont get that error "number" essentially the error is that broadband modem is experiencing connectivity issues, which doesn't provide any insight.
Basically it is a case of SSV wanting the error code to solve the complaint, very lame I know.
Regarding the raspppoe.sys driver from vista I have already tried that & I get different errors such as 797, 633. SSV technician who visited my house didn't know how to do it either & instead said that my pc was faulty can u believe that!
This pppoe issue is really old & on googling I find that to this date people r still facing this problem, some solutions r listed but they don't work for everybody.Its hit or miss.
2. I understand that speeds depend on the server I am downloading from, but shouldn't the "total" available speed/bandwidth of simultaneous multiple downloads add upto the plan speed. Shouldn't atleast one server of the many that I tried downloading from give the proper speed. I mean it could be traffic shaping or sneaky FUP implementation.
3. Do u mean the coating of the cable coming to my house has been damaged & water is leaking into it & shortcuiting the cable.
By the way what is the network switch connected to i.e. other than the user pc's & routers, how/from where does the switch get its internet connectivity from? Sorry, not a network expert but curious how the whole thing works.
I suspected the same about packet loss but I have seen in the past with other ISPs that many times technicians would just patch up the exposed cables which is only a temporary fix.
I guess my major concern is not getting speeds that I have paid in advance for. Really sometimes I don't even get half the speeds.
Another thing I have noticed is that SSV is using a couple of miniature 8 port switches of which all the ports are being used.
Could network congestion because of maximum users on switch cause reduced speeds or is it just traffic shaping?
