Try these settings if you need low ping. I’ve personally tested all of them on my internet:
RX Power: –10 to –14 (for safety, go with –14)
TX Power: 1.5 (keeps the ONU router cool and stable)
Higher TX power makes the ONU generate more heat. If you use multiple devices at the same time, you’ll experience jitter and packet loss since the ONU temperature can reach 65–70°C.
Best setting: TX 1.5. You can try 2.0, but avoid going higher.
Bias Current: 12.5 is ideal.
Try these settings if you’re facing higher ping than your friends, even if they live in the same city and use the same internet provider.
@rikka99 Maybe he has some super advanced ONU wherein he can set the Rx power himself () and can modify Tx power as well, because I'm yet to see such settings in any ONU, having seen my fair share of ONUs
Either he's talking about some jugaad or maybe he's just bluffing
