mgcarley
Founder, Hayai Broadband
i was asked them thay told to me your TCP port were blocked anyhow , Thank u for ur reply sir... there is any other way to slove this problem...
Thanks
Ask whoever has told you that your TCP ports are block the numbers of the ports which need to be unblocked, then call Airtel and ask them to unblock those ports. If Airtel claims they're already open, then probably this is not the problem. It could also be your firewall if you have one turned on, or maybe even your ADSL modem - or any number of other things, for that matter - have you tried your computer on another ISP's connection?
As I said in my previous post, it doesn't work for me on an ISP in a different country either, and I know for a fact all of my ports are open, so with 5 minutes of playing (before deleting that program) my first conclusion is that this software doesn't work properly. My personal opinion is that the software in question is not of very high quality (who codes in Delphi 7 any more???) nor does this program appear to be particularly useful... unless I failed to notice some killer feature... but that's just me.
Thanks
