Problem with Ip.. plz help me!!
  • Thread starter Thread starter abyssman
  • Replies Replies 22
  • Views Views 3,850
when i start my server app, say such as apache and configure to run it on port 80 , i dont want dsl page pop up!!!
You normally need a static IP to post a server ( web site ).
DYDNS provides the connection even if your Dynamic IP changes.
Check in your modem DDNS option.
OK, so were switching to bridge mode
Go here
192.168.1.1 > Advanced setup > WAN
Delete all connection except 0/35
It should look like this
Now, 192.168.1.1 > Advanced setup > WAN > edit 0/35 > next
and change settings like below
rest is next> next and finish
Creating a dialer:
start > programs > accessories > communication > new connections wizard
connect to the internet > setup my connections manually > connect using a broadband connection that requires a user:pass > enter isp name "bsnl" > enter "user:pass" > next/finish
After you switched to bridge mode, download this and install it on your computer.
Download WampServer 2 - Download PHP, apache, MySQL
Now type your dynamic public IP in the browser and see what happens.
You'll also need some way to update your IP with the domain. Most providers provide a free software that runs everytime your computer switches on and it sends your current IP to the provider. Result is that whenever you type your domain name, say, hssp://myname.subdomain.com, it points to hssp://117.195.x.x
essbebe :
bro thanks ,
i know that i need a static ip, so alternately had plans and had registered a free account at no-ip.org(which i think is similar to which u have specified)
and had downloaded an app which updates the server with the new dynamic ip,
was prepared for everything but ............!! :ashamed:
what is this bro .. where can i find this option on my router page bro ?how does it help me?
Sachins :
bro really thanks for your reply , i will definitely follow your instructions , and give you feedback , there is a powercut:wall: here and i am running on backup , i got lot to write , and surely will , but for now i have replied in short and will write as soon as power is back.!!
bro will my torrents run fine in bridge mode ???
================i will write more.. sorry:( for breaking suddenly while the topic is still on!!
Mention your modem model make.
see the "Dynamic DNS option"
http://i23.tinypic.com/oidiro.jpg
Dynamic DNS
The Dynamic DNS service allows you to alias a dynamic IP address to a static hostname in any of the many domains, allowing your DSL router to be more easily accessed from various locations on the Internet.
Choose Add or Remove to configure Dynamic DNS.
Hostname Username Service Interface Remove
sorry for late feedback/reply
sachins ..:
i have done with bridge mode , but it took me long time to connect to net ,
atleast 4 to 5 minutes , 3 or more times it showed some error while dialing ,
was stuck up here :
Oh My god I cant VISIT My ROUTER Page in bridge mode... 192.168.1.1 doesnt work now !! how should i access it ???
:O:huh:
essbebe :
my modem/router make is UT300R2U , essebebe i am not able to access my router page now
before asking i tried https://broadband.forum/mtnl-broadband/2621-bridge-mode-wats-d-router-homepage-address/#post27847
no results i am not able to access router page ...hope u bros hav solution for me...!!
sachins : after i am done with this problem , i will install wamp and test,
i downloaded it now
:happy:
Suddenly my router page is working now i dont know how its possible
To solve the "limited or no connectivity" error, do this...
start > control panel > network connections > local area connection > properties > general "tab" > internet protocol tcp/ip > properties
Copy values from this image exactly.
start > control panel > network connections > local area connection > BSNL Broad Band > properties > networking > tcp/icp > properties
Copy these values in there.
Sachin :thumb:: Thank you this worked and the lan is no more showing error!!!
:cool2: Sachin,, :-)
i Downloaded the wampp tool which you said, but it doesnt support cgi-bin and perl, and i searched addons for that so couldn find it, latter came to know while searching XAMPP Is similar to wamp and it supports perl , i have loaded it and its working fine,,,,,,,,,,,, finally i have set a server at home, :dance::thumb:
http://abhi.doesntexist.com
the above is the site i will be online around 8 pm please check out... thats a webpage i designed for my department fest......but due to problem the site wasnt putup last time. this time i am gonna put it with updates, comment on it please...........:happy:
superprash2003 : only i could find HTTP option in need not the WAN on my router page
Thanks essbebe,sachin, and all other who helped ...........;)Thank you !! cheers:thumb:
With Regards
abhijith
