So for me, it is definitely not staying logged in for 24 hours. I put the computer sleep after the power cut. 15 minutes later I turned back the machine (power came) and I am logged out.
Reliance connection is not connected to my wireless router (BSNL has that) so no one was using the connection (though I doubt that mobile apps pinging the net here and there would prevent the logout).
This is going to be annoying...
BTW. Can anyone tell me how do I configure a wireless router with Reliance modem? It does not work on my current settings that works with BSNL.
Upload speeds are much better than BSNL. Generally if I put anything large on upload on BSNL, pings start breaking and the browsing becomes painful. Not that bad with Reliance. I mean pings are breaking but connection is still very usable.
You need to change the PPPOE to DHCP to make it work reliance on wireless.
Any 1 client be it pc or mobile will keep u logged in as long as some network background activities going. (gtalk,mails,twitter etc.)
Mine working fine for 24 hours.
