Reliance Jio Fiber STB picture quality issue.
Guys, great update.
After the recent set top box update, the picture quality fading issue has been fixed. Now it almost looks like watching stock 0TT apps. This is so good now.
After 15th January things got messy even the Hybrid STB cannot install 3rd Party
about the fading picture there are various resolution settings there were already avaiable exmaple selecting from 1080p or 1080i, for my Samsung Smart 3D TV i had choosen 1080p as that was the best
Is anyone noticing the weird aspect ratio bug on STB ? On Device preference->Overscan, I altered the screen size to fit the TV screen, I noticed the changes made doesn't apply when you open apps like Kodi or other OTT apps. I notice small black bar at the bottom of the screen which doesn't fit the actual 16:9 aspect ratio.
its not working till now..entire screen is not fitting.in some shows it happens especially in some star utsav shows and zee5 shows
@Siddharth070999 - I had that issue way back in January. The problem lied in my TV's resolution settings, I changed it to "Best fit" or "smart fit" and all resolution issues were fixed. Some old shows are in 4:3 AR and if the screen looks stretched then OTT channel might have done that or it could be your TV's resolution settings.
