Ok so let's get back to main discussion about picture quality. So there are 3 blue coloured hybrid set top box variants with almost similar specifications but all seem to have some issues like
1. Washed out colours or distorted colours.
2. Low resolution picture specially with some live TV channels.
3. In general even apps such as YouTube, Hotstar, Jiocinema appear appear SD quality only despite showing Full HD in settings/nerds stats.
So now what can we do about it. Technician offered me that he would change my set top box but I believe it won't make a difference as they all seem to be same as others have also reported similar picture quality issues.
May be then we all should bombard jio customer care with complaints regarding picture quality or write emails explaining picture quality issues. Ask them to replace all defective set top boxes , or provide software updates which might correct picture quality.
Issue could be the one I mentioned poor colour calibration (box sending limited rGB and not full rGB) or HDR issue as someone suggested.
I have used lot of china based set top boxes and I believe the hardware specifications specially CPU/gpu is good . It seems to be using amlogic s905x2 with mali g31 mp2 which is quite good same as my Mecool set top box. So I believe may be just a software update will settle picture quality issues.
