Reliance Jio Fiber Wi-Fi Mesh
  • Thread starter Thread starter mayank yadav
  • Replies Replies 151
  • Views Views 41,327
@gizmofreak It’s working great. You won’t feel any difference since it’s a mesh system. It is the cheapest mesh for Jio Fiber users.
I had a choice to purchase either TP-Link mesh system or Jio mesh.
tp link is around Rs. 10-15k with 3 devices which consists of 1 primary device (needs to be connected with router via wire) and 2 wireless nodes
but in case of Jio Fiber the primary node is the Router and you can add as many nodes as you need, The only downside is that it only works with Jio, so I had a choice either spent Rs.2500 or Rs.10 to 15,000. I went with 2500 😁
No just Rs 2500. Just purchase one mesh for now and see the range. If you need more, you can purchase them as per your requirements.
I was saying e.g. you need mesh for 5 floors, then ground floor router should be wired with 1st floor mesh (1) and other 2,3,4,5 will work wirelessly
I need the wifi range just in my master bed room and the primary ONT is installed in the drawing room which is a little far. So what I was planning on doing is placing a mesh node in the passage hoping it would be wireless and be done with buying one mesh device only.
The local technician pushes for purchasing it from outside because they expect you will ask them to get one and install. They make quick money thru that.
