... snip ...
i am using Open
DNS in my LAN configuration settings of
Windows
... snip ...
i have disabled DHCP and assigned manual ip to my comp
I have disabled DNS relay so that
router dosnt use mtnl's dns
So far all sites opening perfectly
also noticed better browsing speeds
I have had a similar setup from day one (April/2005) of my TriBand service with one exception - run my own DNS server. Yet, I have been experiencing the same problem since mid May/2007.
IMO, the problem is not with DNS or Dynamic/Static IPs. When this happens you will notice that DNS resolves but connection to the site times out. If you do a traceroute to the site you will notice that it exceeds max. hop of 30, implying that packets are not reaching the destination.
IMO, this intermittent problem is not with DNS or your LAN settings, it lies somewhere between MTNL and VSNL (MTNL's upstream ISP).
IMO, this problem is way beyond the help line folks at 1504. Send your complaints to someone higher up in the chain.
Pls. see my earlier posts in this thread.
