Torrents goes dead between night unlimited period
  • Thread starter Thread starter abhayshow
  • Replies Replies 19
  • Views Views 4,059
check the port forwarding mate.....
i have been using the utorrent for years.........try once a private tracker.
and keep the outgoing data in encypted .......there is a option there.
FYI, 90% of my downloads are from private trackers. And I'm using uTorrent when I first started using torrents and the outgoing data is in "Encrypted" mode.
But still I see RED icons (dead torrent) when I wakeup in morning. Today again I have started uTorrent 1.7.7 and I'll post my result here.
Good.. Even, i am using torrent from early 2004... Mostly private trackers only.. Recently, encryption is enabled aswell... But, this has nothing to do .. many r facing the same problem (have posted in bwt also) !!
Use u torrent.Disable windows firewall.Have a tcp fix.In windows xp sp2 default half open windows is only 10.Bitcomet has a built in TCP fix.
I am using Azuerus. Every time i connect it i says dht firewalled.what to do abt this problem.....??what is port forwarding....??? How is it done....???thanks...!!!!!!
I'm having similar problem, though I'm not using utorrent or bittorrent. Sometime in the night my connection is freezing, in the morning again i've to fire-up the connection to get the torrents start download. This problem is happening only since 3-4 days.
The author of "Imran's Broadband Helper Utility" has said in his program:
"your service provider can implement a program on server side which can reveal that wheather you are opening some web pages at some fixed duration or not, and if not they often throttle your bandwidth or simply disconnect your connection (downloading a big file using utorrten of fdm is not opening web pages)"
I firmly beleive this is the actual resason behind "Torrents goes dead between night unlimited period", so u guys can try his solution then report here the effect of his solution.
for more info, see the thread:
https://broadband.forum/bsnl-broadband/33343-ultimate-night-free-usage-manager/
contact bsnl and take them to consumer court.they are violating net neutrality principle.i urge to all to write a letter to TRAI.Comcast in US was found doing this and was found guilty.If i was a bsnl user i would have taken them to court.
hmmm.
this is the REPLY i was expected here.
:O
the simple reason could be that network is congested with simultaneous downloading during that time. I'm a H1350 user and my browsing and downloading goes a snail's pace between 2 am and 8:30 am, but miraculously returns back to normal at 8:30 am.
