Upgraded to Reliance Thunder 1099 4Mbps no FUP Broadband Plan!
  • Thread starter Thread starter warpspeed
  • Replies Replies 92
  • Views Views 28,216
i have windows 8 enterprise :D that's why i asked you.
just waiting to install it ;D [i cant wait]
your pc theme look's like win 8 and it is win 8 :D
Man your internet is A+ Good* mine is bad :( 200+ ping 124KBps
you may wanna use Zbigz.com for torrentsi don't know it will work or not just give it a try ;Dyou use idm i know a trick for IDM good* for high speed user's :DGo to>Option's>Connection's>connection type=Lan 10mbps>Default max connection's=16 that's it :D works good give it a try maniac 123 ;Dthis trick will increase the number of connection's and max your DOWNLOAD* speed :)
i think ur with 1mbps plan right and ur getting proper speed according to ur plan
i think i seen ur earlier posts .
