i took that and sent to him.... he said he is supposed to receive 15 STB today, once he get that he will replace it... letz see...
My Comment to D2H is
D2H should have the updated STB to get right PQ in the LCD/LED compatible, Not all users will choose HD Box's.... hope they understand this...
@pkarthik24 ,
Just to clarify, on the newer HD box which he has temporarily given to you, are you satisfied with the SD channels PQ on it ? And the signal levels are the same on both the boxes. Right ?
YES SD channes PQ is PERFECT in their HD BOX
@ pkarthik
Ya. Are you satisfied with SD channels with D2H HD box / it shows same quality like your SD box?
What are clearity %? Do you think they are good in HD channels if you have an HD
TV?
What is size of HD DTH dish antenna / they use ur old D2H antenna?
YES I am satisfied with the SD channels in their HD Box PQ is perfect....
The Strength/Quality Signal % are same as they use my existing line only...
Same Dish as as the existing line used
