Will this be possible???
I can i get/buy a 90 cm Satellite dish outside in the market, Will the D2H people install the LNB to it and make the rest of the installation? if this could happen then it would be very good, i would get a very good signal and quality strength.
Did anyone thought of this or have tried it?
Regards,
Nandakumar
I dont think this is possible because-
1) There will be warranty issues.
2) There will be hardware compatibility issues.
3) From common sense point of view, if a larger dish is required then I see no reason why videocon won't provide it in the first place. They can give an option to the customer to select a larger dish and charge accordingly if the customer wants a larger dish. Also, if you think the other way then Videocon can simply throw the large dish for all connections and jack the prices. They are doing neither of these, so I think that whatever size they are offering should be sufficient to serve the purpose.
Of course, there is always DIY, but then points 1) and 2) come into picture for that.
Regards,
Nandakumar
