Thanks a lot for the info. Currently I am using ADSL2+router STARCOM rented form BSNL. I heard that BSNL doesnt give choice to choose the modem, when I upgrade to Wifi router. So I thought of purchasing and configuring it on my own.
Any idea about the brand/model BSNL gives ?
Check in MERCYS(electronic shop). NetgearWGR614v9 may be available for1000/= approx. With bill and guarantee card. 1 year. ( wifi range say radius about 10 to 30 feet )
If WIFI range is more ( SAY above radius 30 feet higher heights ) buy a higher priced WIFI Router Buffalo model. ( check the Power output and and multiple antennae)
In ebay.in check only wifi routers. available for900 onwards.
Para two:
Please Post Device info of your Starcom ADSL2_router.
If you ask for a wifi router ( usually Adslmodem+4lanport+wifi router) rent will be80/= P.M and you have to return the adsl modem
Contact J.T.O Broadband section Availability.
Outright purchase 1800/= plus 10.3% taxes )
Check my "Sticky" post WA3002_g4 quick reference in this forum.
Para two:
