^ Is that how they are giving the service? Based on the proximity to the exchange? I have read that 16 Mbps speeds are available in 70% of our city, and so I would like to believe otherwise. Additionally, when I had called up Customer Care just to enquire if any equipment change would be required, I was told that the existing equipment would be sufficient.
its available in 70%, but what about the remaining 30%
also, you must be living in a relatively large city, so its available there
i spend 1/2 my time in gurgaon and the other half in manipal
gurgaon - take whichever connection whenever you want
manipal - ofthen they(airtel) are running out of lines, even with most people taking only 256-512kbps connections, and not higher speeds, also speeds>2mbps are not available there, dont know the reason
but in
ADSL, wiring distance from the exchange does make a difference
