Airtel V-Fiber (VDSL) - Link Drop & Other Issues [HELP]
  • Replies Replies 381
  • Views Views 155,653
@manojrk @tech_bng what kind of changes in stats do you guys see after the internet is connected for some hours?
Like Downstream Rate, Upstream Rate, Downstream SNR, Upstream SNR, Downstream Line Attenuation, Upstream Line Attenuation etc etc?
Please share the screenshots after restart and after certain hours of usage?
@waterloo_sunset @AgentX @chplff94 @itzmynet @wecaz Any thoughts or inputs so far?
@Adidam Only the sync rates fluctuates for me from 85 Mbps to 115 Mbps. Minor changes in rest of the stats. Still getting those FEC errors but no changes in the stability. Like Karan mentioned VDSL is prone to several external factors and only Airtel could possible fix it for good.
@manojrk The engg. has used some button type thing to connect the wire instead of connecting it to the Sub-Pillar or DP jumping.
So wire is connected with a small button type thing.
I am seeing no improvement.
@Karan ^^ Is it better i mean using button instead of using sub-pillar jumping?
I am seeing disconnection. Not sure What to do next?
Because engg. are also limited in knowledge and are lazy.
for testing purpose ....members who still facing issue ...
could u please disable SRA and enable G.INP ? and check if connection stability improves ( SNR, FEC , CRC etc ) ?
Beetel 777VR1 is best out of box for me , ZyXEL VMG1312-B10A needs tweaking but performs same like 777VR1
i cant PM you because i'm new member to this site soo its disabled for me
Asus have more advanced functions ... but its modem have MediaTek MT7510 chipset so bit unstable sometimes ... wireless range is maybe 10% to 20% better than other modems i have ........
u can mail me chplff94 at gmail dot com
