MediaFire
Twisted
micromax is as good as any new CDMA modems , but works better than the modems which BSNL offersvin said:Known devil is better.
How is micromax 300c performance? Is it easy to install for people with minimum knowledge on devices,software Etc.?
Is it adoptable to EVDO rev.A standards?
If you recommend will wait for a new one at Ebay.
capitel or prithivi
its easy to use , pretty easy than the capitel modem in setting the profile and the UI is simple
u wont get any new one on ebay for sure !
CDMA is almost dead now , getting a modem is difficult to impossibleInternetAddict007 said:I've been hunting for a Micromax 300c for so many months..
Nowhere could I find one. Nowhere in the Web. There were a few Listings in Ebay but over priced, and when I contacted the seller he told me it was not in Stock and to prevent people from ordering it, he priced it 10X times.
Then I settled for an unlocked mts ac 2766.. Then got a prithvi ue 100 also.
i have two modems , even though i use only one , i hold the other one for standby for future use
BSNL could pull the plug anytime on EVDO , there isnt any connection at par with BSNL EVDO , so still sticking to it
