Considering buying Spectra. Need some advice
@Dark_Nate If you’re not at one location, don’t you need fast LTE or WiFi wherever you are? How can Spectra at home take care of all locations? :)
@aakshey Yes. The only reason I'm considering Spectra now is because I'll be in Bangalore for a while.
@Dark_Nate Is it unlimited? Do you get 100 Mbps to all servers all times? Even during Corona?
With ACT I’ve seen when I was on 150 Mbps, I would always get 150 Mbps regardless. When I moved to 300, I would get 250-300 to ACT servers but 150-250+ to other local servers.
So as you move up, you might not get full speed across all servers. Whereas with 40-200 Mbps speeds, you might get 110%+ speed to all servers.
@aakshey Go to the BSNL sub-forum and see the FTTH section. I'm facing the same problems everyone else is with BSNL FTTH.
No, it's not unlimited, unfortunately, I do not seed while I'm in Meghalaya.
