Anyone using CM11 in 2012 Nexus 7?. I am stuck in M7, yet to get M8. Updates are OTA right?, I installed using Windows installer. Tweeted to them. No reply.
Sir, normal builds and installer builds seem to be different. Normal builds are getting updates not installer builds. They are not concentrating on installer builds, which should be opposite.
The builds are same, only the installation procedures are different. If you know how to flash a ROM from recovery, you can download the M8 Zip above and gapps from the below link and flash it.
