Before FUP: 50 Mbps Down, 4.5 Mbps Up (Almost 1:10)gagan97 said:Can anyone tell me what are the contentin ratio for Hathway Docsis 3.0 plans. They have not listed it on their website. While other ISP's like Tikona do list contention ratio on their site. Its very important to know contention ratio as after FUP the speed is going to drop to upto 1mbps and that time contention ratio will play a major role in exactly what speed u get.
BTW anybody used up FUP limit and now under 1mbps or 512kbps speed can tell me what is the exact speed you are getting.
After FUP: 1 Mbps Down, 1 Mbps Up (Exact 1:1)
This only applies to the plans in which speeds after FUP are 1 Mbps, don't know about the ones with 512 Kbps... they might be 512/512
Uhh... better data caps?vj_0987 said:fantastic speeds what more u want if u r in india...
