issue of vipo of bsnl ftth
Status
Not open for further replies.
BSNL
as i taken FTTH connection past 5 month's ago till the date of 10-Jan-2020 they BSNL did not given provided me voice call & any body can help me to config voip for voice calls to my modem & modem model is 1143.
Dear @SHASHI KUMAR V , there is no common configuration that will work for all as the configuration varies from circle to circle and user to user. I can assure you that, I was also asking around the configuration of others, but none of them worked. The IP Address, Default gateway, DNS, SIP Server address are different and unique for each circle or user. The best you can do is request your LCO to provide you the configuration details or ask them to configure it for you.
Does your Broadband plan have Voice included? If yes, the AE will be able to configure the Voice. Each district has a FTTH helpdesk.
If you can get the number of the helpdesk, you can call them and they will enable voip and update it from backend for your ID.
ANY ONE PLS HELP ME REGARDING MY VOIP CONFIG ONT . NOW THE STATUS OF VOIP IS UP. BUT VLAN-ID IS SHOWING 0 (zero )
PLS.... PLS.... PLS.... PLS.... PLS.... ANY ONE HELP ME AS I AM BEGUINE REQUESTING
Status
