guys I don't have to open manualy mobile parter, whenever I connect my dongle it automatically connect with internet.. no need to dial any thing in windows 7
I have tried something new this time will update u all in 2-3hrs... if it worked......
@onenessboy
hi nice to have u back actually internet does not disconnect it just stalls.... i.e monitors are active but there is no bandwidth
here is same problem with this guy too... ironically I even posted in that thread I have tried this out i get a message that ur already updated and you dont require this... ( not exactly the same words )
Yes anant. I am using ppshsdpa apn to connect it speed is usuallly arount 1.50 mbps average.
is anyone in Delhi able to use APN as ppshspda as I am getting 619 error on it...
one more thing mobile partner is showing 92% signal strength and MDMA shows less than half i.e around -83 to -89 ?
I noticed one strange thing once monitor light is still active and its just stalling and there is pretty much no bandwidth in it ...the signal strength drops to -103 dbm and once I reconnect it manually the signal strength comes back to -85 dbm.....The thing is until and unless I reconnect it manually the signal strength wont come up on its own ?
nt working it is still stalling ....is anyone using mtnl 3G on XP sp3....... ??
Hi Anant,
There is no problem on XP SP3.....bascially..
do following:
* if you connecting to your laptop then, take to some other place (at least to terrace) where you are near by MTNL tower (This is just for Testing) This should clearly work otherwise then network issue.
* I told you to use just a dialup connection for connecting --- check this...
* Try your usb stick with your friends system or some other which have windows 7
* If possible then tryout any otherfriends 3g datacard for testing.
* Last contact mtnl people directly and escalate it...
PC is running XP and on laptop got win7...on laptop it just DC twice did not stall so auto re connect would work I am also pretty much outside...I think when the modem heats up it starts to stall...if its cool everything works fine.....I think situation is going out of hand now..
Speed test results on on my Laptop on Win 7 did it just now..
speeds are looking very good above..even pings...
regarding heating up issue... there is some caluction of different usb's cards.. according to that if dongle heatsup 82 % then it will disconnect..
i found some thread some forum about this heating issues.. just google it.. i think that is indiabroadband forum i think...
check it out... But i never faced any heat issues..as i will put heavey torrents load on my laptop...
