CRC9 ANTENNA 12dBi FOR 3G USB MODEM DATA CARD & ROUTER | eBay
hey popcorn antenna should increase dBm and decrease signal strength . but 4 good speed we want 65 to 75 dbm then signal strength better. here is -79dBm after all desi jugads. tell me how to decrease dbm and get great signal?
Be carefull. Your 3G modem should be compatible with this router. check the list on TP-Link website before taking any decision.
I use k3765 VF unlocked 3G 7.2 modem!
I have been using SMS routers which are wifi enabled and allow data cards to be pluged in and used over wifi. Asus also has a similar product. SMS costs around 5k Asus is 3.5k
with this TP-Link MR3220 my signal strength boost? i mean if i buy this and plug usb data card then my signal strenth is boost and better then normal ?
I think I have got too many towers in my area and once I jump to another tower, there is a good chance I get a drop in signal and a disconnection.
It's high time MTNL look into this.
hmm..ya if anyone is buying this do let us know how it goes..seller seems to be selling them pretty well
u will need to put ur USB modem in it ..which is nt gonna result in signal boost mst prbly
finally the modem is DC and connecting on its own it was a dam signal issue...so much time gt spend on this grr...
