I use my connection with Win 7. It gets disconnect/reconnect after 1-2 hours on download. Connection gets stalled but connected after 4-5 hours irrespective of download. To fix this, I have to manually disconnect-connect.
The interesting part is that sometimes, after reconnect, the upload data(a few Kb only) is being sent, but download still remains zero. In this case, I have to do disconnect-connect upto 3 times to get it working.
I assume that the modem is not hung, just the network issue. Comments welcome on this.
heheh you have the exact same problem like mine..nice to have u here...now @amish wont say is this only anant specific problem
btw have u tried the
windows 7 fix yet ?
Guys,
I have created a batch file to reconnect the connection in following two scenarios:
a. When it gets dropped/disconected.
b. When it is connected but internet stops working
I have tested it for the first scenario.
Anant, can you verify whether it solves your connection stalling problem?
Here is the batch file
Replace with the connection name you dial.
Let me know if it works
hi thx for making a batch file I will check it out
one more thing...if I ping
google when its getting proper signals which is around -83bi to -85dbi I get 0% packet loss and pings of around 200 to 500ms but when suddenly the signal drops to -103dpi I start getting 100% packet loss and requests not complete if I ping google...internet does not work either...
@wecaz
running ur app in the background I think its pretty cool... basically I think it will reset the connection if it starts getting packet loss
will run some test on it tmrw on XP SP3 as thats the main download system
