But before I even connect to dial-up, the dongle itself searches for a signal. Before the problem occurred, I used to get 3G network (blinking blue light) even if I had not connected to the internet via dialup. So even now, before connecting it should indicate 3G signal availability just liked it used to do before.
Another thing is that I am unable to get 3G services even on my mobile phone.
And even I wanna use Mobile Partner but is giving me some issues. I had sent you a private message regarding it but I guess you skipped it by mistake.
Hey I can finally use MTNL SIM on my dongle. All thanks to you.
But I am using a dial-up connection. With Mobile Partner, I am experiencing a very strange problem.
Mobile Partner cannot connect to the internet, but when connected via dial-up, I can disconnect via Mobile Partner.
Mobile Partner cannot read my data card ie signal strength is 0%, but it still shows the upload and download speeds.
In short, mobile partner doesn't works when disconnected. Only once I connect via dial-up, mobile partner can be used.
Any help?
And how do I select 3G network on Mobile Partner? I have the software installed but I don't use it due to the strange problem mentioned above.
