Yesterday I got Dish TruHD box installed and hooked up to my SonyBravia KDL40-v2500 NTSC LCD TV. It worked great. Both Component as well as HDMI are working. I enjoyed Indo-pak match on Star Cricket HD. The technician first setup the Dish and LNB to receive the signals as well as the OTA updates. He then connected the TruHD STB and triggered the OTA firmware update to STB. Then switched the video source to Component and configured the HDMI settings to 60Hz. Then switched the video source to HDMI. Now both video sources are working like charm. So, whoever is brining the NTSC TVs from USA, no need to worry at all. Just install Dish TruHD and get rid of all convertors.
hello everybody.....no need to buy pal to ntsc converter, if you use only for tv.there is some dth services supports for ntsc tv's.in sun dth have only in AV,in Tata Sky u can have in HD and AV.in dish Tv only HD.but don't buy blindly.....before buying ... ask the technician\distributer..... bring STB, which supports for Ntsc Tv's...i'm using the sun Dth.. it's working excellent...
