PPPoE over wireless? (BSNL)
BSNL
I am new to the world of PPP as I have never used this before. Just came home for the holidays and we have a BSNL dataone broadband service. Now, what I have is a wireless connection to which I connect and then dial up a pppoe connection and surf the web. To configure it on Windows I did this: Connected to the wireless Create a new connection -> Set up my connection manually -> Connect using a broadband connection that requires a username and password and so on with the details.. In Linux.. Connect to the wireless (that I could already see) Then I used pppoe-setup (from rp-pppoe) to configure the pppoe thing. I entered the username and password, chose wlan0 as the device, and no firewall. However, when I run pppoe-start it times out and does not connect. Can someone please help me with this!
1.mention the modem/wifi router you use.
2. Do you use a desktop or laptop computer ?
3. Either of them has a wireless lan card /
4. Try in Windows first. ( LINUx advice by others )
5. See and select your unit , if available.
REF:BSNL BROADBAND MAIN MENU
.....h t t p://chennai.bsnl.co.in/BBS/WA3002G4.htm with screen shots.
1. SL2_141 (Type B0
2 & 3. Laptop - and of course it has a wireless card (Intel 3945 to be exact)
4. It works in windows, I already said that.
5. There are no instructions to configure this on Linux on the BSNL website.
1. SL2_141 (Type B)
2. Laptop
3. Intel 3945
4. Works in Windows (I already said that)
5. No information on website about Linux
And so that I do not have to repeat myself, I can see the wireless in Linux and can connect to it, but I do not know how to sign in using my username and password.
Maybe this reply will be accepted!!
I am sorry to be so rude, but this forums sucks. I have posted a reply to this thread about half a dozen times now, and each time I get a message telling me that my post awaits moderator approval, however there is no update.
The latest update on the situation is that I have managed to connect to the internet using roaring penguin software. I am assigned an IP address and everything. Here is the output of my ifconfig.
Code:
oogly rahul # ifconfig                                                          eth0      Link encap:Ethernet  HWaddr 00:15:c5:1b:9f:d4                                    UP BROADCAST MULTICAST  MTU:1500  Metric:1                                       RX packets:0 errors:0 dropped:0 overruns:0 frame:0                               TX packets:0 errors:0 dropped:0 overruns:0 carrier:0                             collisions:0 txqueuelen:1000                                                     RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)                                           Interrupt:17                                                            lo        Link encap:Local Loopback           inet addr:127.0.0.1  Mask:255.0.0.0           inet6 addr: ::1/128 Scope:Host           UP LOOPBACK RUNNING  MTU:16436  Metric:1           RX packets:44 errors:0 dropped:0 overruns:0 frame:0           TX packets:44 errors:0 dropped:0 overruns:0 carrier:0           collisions:0 txqueuelen:0           RX bytes:2584 (2.5 KiB)  TX bytes:2584 (2.5 KiB)  ppp0      Link encap:Point-to-Point Protocol           inet addr:117.201.81.152  P-t-P:117.201.80.1  Mask:255.255.255.255           UP POINTOPOINT RUNNING NOARP MULTICAST  MTU:1460  Metric:1           RX packets:3 errors:12 dropped:0 overruns:0 frame:0           TX packets:5 errors:0 dropped:0 overruns:0 carrier:0           collisions:0 txqueuelen:3           RX bytes:54 (54.0 B)  TX bytes:83 (83.0 B)  wlan0     Link encap:Ethernet  HWaddr 00:13:02:ab:1c:a1a           inet addr:192.168.1.2  Bcast:192.168.1.255  Mask:255.255.255.0           inet6 addr: fe80::213:2ff:feab:1ca1/64 Scope:Link           UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1           RX packets:23 errors:0 dropped:0 overruns:0 frame:0           TX packets:64 errors:0 dropped:0 overruns:0 carrier:0           collisions:0 txqueuelen:1000           RX bytes:1968 (1.9 KiB)  TX bytes:12960 (12.6 KiB)  wmaster0  Link encap:UNSPEC  HWaddr 00-13-02-AB-1C-A1-77-6C-00-00-00-00-00-00-00-00           UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1           RX packets:0 errors:0 dropped:0 overruns:0 frame:0           TX packets:0 errors:0 dropped:0 overruns:0 carrier:0           collisions:0 txqueuelen:1000           RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
However, I am unable to do anything with the internet. Can't browse, can't ping, everything just hangs at looking up google.com or similar!
try searching the web for info on how to set the gateway and dns servers for your linux...set gateway to 117.201.80.1 and DNS servers to those of opendns.com then report back...
Code:
googly rahul # ping 192.168.1.1              PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=3.99 ms64 bytes from 192.168.1.1: icmp_seq=2 ttl=64 time=1.13 ms64 bytes from 192.168.1.1: icmp_seq=3 ttl=64 time=1.17 ms64 bytes from 192.168.1.1: icmp_seq=4 ttl=64 time=1.12 ms64 bytes from 192.168.1.1: icmp_seq=5 ttl=64 time=1.46 ms^C                                                       --- 192.168.1.1 ping statistics ---                      5 packets transmitted, 5 received, 0% packet loss, time 4003msrtt min/avg/max/mdev = 1.120/1.777/3.991/1.114 ms
Code:
googly rahul # ping 72.14.205.100                                        PING 72.14.205.100 (72.14.205.100) 56(84) bytes of data.                 From 192.168.1.1 icmp_seq=1 Destination Net Unreachable                  From 192.168.1.1 icmp_seq=2 Destination Net Unreachable                  From 192.168.1.1 icmp_seq=3 Destination Net Unreachable                  From 192.168.1.1 icmp_seq=4 Destination Net Unreachable                  From 192.168.1.1 icmp_seq=5 Destination Net Unreachable                  From 192.168.1.1 icmp_seq=6 Destination Net Unreachable                  ^C        --- 72.14.205.100 ping statistics ---                                    6 packets transmitted, 0 received, +6 errors, 100% packet loss, time 5005ms
Code:
googly rahul # route -neeKernel IP routing tableDestination     Gateway         Genmask         Flags Metric Ref    Use Iface    MSS   Window irtt192.168.1.0     0.0.0.0         255.255.255.0   U     0      0        0 wlan0    0     0      0127.0.0.0       127.0.0.1       255.0.0.0       UG    0      0        0 lo       0     0      00.0.0.0         192.168.1.1     0.0.0.0         UG    0      0        0 wlan0    0     0      0
Code:
googly rahul # cat /etc/resolv.conf# Generated by dhcpcd from wlan0nameserver 208.67.222.222nameserver 208.67.220.220nameserver 192.168.1.1# /etc/resolv.conf.tail can replace this line
