Problems with Reliance Broadband Thunder Plans
  • Replies Replies 1,271
  • Views Views 195,967
Status
Not open for further replies.
yashleo21 said:
Dat ping..
Even my Idea's 2G (edge) has much better ping :P
C:UsersVertigo>ping 173.194.117.52 -t
Pinging 173.194.117.52 with 32 bytes of data:
Reply from 173.194.117.52: bytes=32 time=336ms TTL=54
Reply from 173.194.117.52: bytes=32 time=313ms TTL=54
Reply from 173.194.117.52: bytes=32 time=332ms TTL=54
Reply from 173.194.117.52: bytes=32 time=310ms TTL=54
Reply from 173.194.117.52: bytes=32 time=329ms TTL=54
Reply from 173.194.117.52: bytes=32 time=307ms TTL=54
Reply from 173.194.117.52: bytes=32 time=326ms TTL=54
Reply from 173.194.117.52: bytes=32 time=308ms TTL=54
Yashelo. You still facing issue? It's been more than 1 month my pings are now stable all day all night. Ask them to upgrade the E1 line on your particular dlc. Take a help from dot and nodal officers.
Is it just me or the Upload speeds have been capped at .35mbps. I used to get around .70mbps few weeks back but since last 3 days my uploads speeds are gone for a toss.
https://www.speedtest.net/my-result/3097578772
Harkirat Singh Saggu said:
LoL ... reliance is not even near perfection ... BUT ... it is the only *BEARABLE* ISP in india. For a truely worry free unlimited data usage, the small hiccups are expected. :) :D
Hey...r u on adsl or metro ethernet ?
I am on ADSL2+ , & no i usually get this upload speed, mostly around 90-95KB/s ..but sometime 65-70KB during very busy hours. But about 80 % of the time i get this upload speed.
I see you in ludhiana too, i am from BRS nagar, where are you from ? May be the local exchange capped your upload speed ?
Speed test right now,
I also live in B Block BRS Nagar. Do i just lodge a complaint through the portal or talking to someone in the exchange would help ?
Status
