Problems with Reliance Broadband Thunder Plans
  • Replies Replies 1,271
  • Views Views 195,967
Status
Not open for further replies.
Stealz said:
Hi,
could you help me in configuring my router,TP-Link TD-W8961ND ADSL2+ Wireless Modem Router for Reliance(thunder plan - 1199)
Peace
plz post the some screen shot of your device ... what options are available .. but to get started these must be enough :-
Harkirat Singh Saggu said:
FIrst of if your router is asking for a username and password for the connection then you are doing it wrong. Reliance is not a regular ADSL dialup setup. It is a captive portal based service.
I have a BSNL Huawei modem MT841 which works fine (tho i am using origianl modem + router setup , cus its always better than standalone ones)
Try selecting a DHCP option, as i don't know what configuration options your modem asks for, i can't help certainly.
But try the following as in the image below !
http://imageshack.us/photo/my-images/708/ylmj.png/
Connection type should be sometime like : - DHCP, Automatic Configuration - DHCP etc,
Set VPI = 0
VCI = 35
these are the most basic settings needed.
If you still can't connect then post a screenshot of the configuration page where it has the adsl connection options!!
Good Luck !
This quote is from another topic ... check here if you want to but these must work just fine.
https://broadband.forum/topic/58664-configuring-d-link-wifi-dsl-2750u-for-reliance-broadband/page-2
What should I select in
Grievance Pertains to Central Government Ministries/Departments State Government Departments ?
AND in:
Select Ministry/Department: * Grievance Pertains to:
Status
