Problems with Reliance Broadband Thunder Plans
  • Replies Replies 1,271
  • Views Views 195,967
Status
Not open for further replies.
Will you be going back to the 327.23 drivers?
I haven been able to get into the game for hours. Constant driver crashes. Apparently, it's a known problem, especially on NVIDIA cards.
Fuck you, EA.
Finally got the game to work properly.
Resolution - 1600x900 60Hhz
Video settings- High
Now I just get a little bit of stutters at some point of the game (its beta.. and might be the servers too )
And yeah I'm back to the latest official drivers provided by Nvidia.
Whats your rig config?
A Phenom II X4 955, 4 gigs of RAM and a GTS 250 (yeah, my card is a relic), 1366x768.
Before the crashes, i got into the game once and high gave me 32-42 FPS (surprisingly). Stuttering rampant.
But the game is a processor hog. My CPU usage was at 90%. Need to overclock.
By the way, you didn't get driver crashes?
I'm pulling my hair out and still can't get it to work.
Nope. Not even a single driver crash.
600 series will be cheaper as 700 is launched.
If thinking of buying a new graphic card then you can go for the 660 or 650ti. More than enough.
the service given by the local technical guys and those at the customer care is really pissing me off,they are really useless piece of shit.if you want your problem to get solved directly complain to the department of telecommunication,that might be a better option.reliance is a well renouned company and they should see that every region should be getting same preference in respect to connectivity and customer service....
Status
