Superfan Ceiling Fan
  • Replies Replies 187
  • Views Views 32,431
Opinions?
LOL, not plug and play. You will need an electrician for that. I know how to do it hence did it myself :D
Right, by motor I meant the central round part of the fan.
I know its central part. But who knew?
Its superfan! It could be plug and play technology! :p
Like detach this and detach that and you reach center.
Remove motor -pluck!
Fix motor - click!
Attach that and attach this!!
And you are done! :p
Hehe. They should seriously consider getting rid of that logo/LED light on the motor. The LED on the new motor is even brighter now. It is impossible to sleep in the night with the fan on standby (turned off using remote). I like my room to be pitch black in the night.
