Superfan Ceiling Fan
  • Replies Replies 187
  • Views Views 32,431
Opinions?
How do you know that remote is working fine when fan itself is not moving?! :)
Yup, it blinks when we press any button on the remote. Like if we press the speed 5 on the remote, the light blinks 5 times denoting the speed.
Now I wonder, may be remote is faulty?! :D And its not turning the fan on!
Is there manual on/off/speed switch somewhere?
What if you turn fan off and remote is lost somewhere under pillow or sofa etc. And you can not find remote.
How do you handle this situation?
