Superfan Ceiling Fan
  • Replies Replies 187
  • Views Views 32,431
Opinions?
Once you have multiple units at home, I think you can use a single remote to control them all and keep the rest of them for backup.
on the top model which does not require a regulator as it is integrated in the fan itself. cheaper models have regulator support i think.
