Superfan Ceiling Fan
  • Replies Replies 187
  • Views Views 32,431
Opinions?
Its better to order from their own online store, except you dont get any discount coupons or card discounts. But they have quantity based discounts.
not much difference in speed as compared to normal fans, but its fast & good breeze too.. but you will find a huge difference in speed when the power switches to Inverter.
I think line switching to inverter shouldn't affect the speed in this case as this has a DC motor so change in AC voltage shouldn't affect the speed. This is the reason they say that a conventional regulator doesn't work with this fan. Conventional regulator reduces the voltage output which reduces the speed of a regular fan.
Correct me if I'm wrong here.
