i have buy a docomo sim card two week ago,.and i want to know what is speed of docomo gprs. i search about it on google but their are no satisfy answer .when i check data plan on it's website i surprise to know that docomo increase his GPRS data plan price .is they increase speed also ?
Kindly provide us your Tata DOCOMO number, your alternate contact number and email ID so that we can get in touch with you. You can also go to the following link - Tata DOCOMO Chat to get your query resolved through a Live Chat with our Customer Care executive.
Thanks and Regards
Customer Care
Tata DOCOMO.
Thanks for reply i have recharge my Tata docomo sim with 69 gprs pack
when i try to connect to internet i can't connect to internet .
i try so many time but i can't get connect through net
now what should i do ?
hi jai !(1) to use docomo gprs u need to have atleast rs.1 in your main balance (even if you have a gprs plan activated). (2) their speed might be 28kbps or whatever in pune bcoz their server is situated there. in ap download speed doesn't cross 20kbps with heavy fluctuation in speeds. (3) it allows you to login only after several rejections. (4) their billing system deducts 10-15% extra bandwidth usage (5) so for rs.69 recharge you would end up with only around 2.2 gb as against 2.5 gb advertised by docomo.i did such a recharge (rs.69) twice in the last two months and raised this issue at this forum and got same standard reply (which you got here) from "tata docomo care" here with no corrective action. it only appears they want to pretend to be attentive and "listening" to the customers without actually solving any of the issues raised.
Use correct APN:: TATA.DOCOMO.INTERNET
Keep Min. Balance: Rs.1/-
