Airtel V-Fiber (VDSL) - Link Drop & Other Issues [HELP]
  • Replies Replies 381
  • Views Views 155,653
xX6Un
the airtel guy came and replaced the Huawei 630 router with binatone dt 920w. speeds are fine but my mobile is not getting connected to wi fi?
I also have the same problem from 12 September 2017. Still now. No improvements. I complained to airtel but my problem is going on in last one month.
Hi i have been given the D-Link 224 and since the time i have upgraded i have been having trouble with the dlink connectivity issues. earlier i have trouble connecting to the internet and now i have trouble with wifi. Though the strength is good it keeps getting disconnected and will have to reset my wireless network to reconnect. have anyone else been facing the same issue. Please help.
Same here, this will only happen till you are connected on wifi,use it through ethernet,you will not face any issues..its the WIFI part which is bugged and airtel technicians have no idea whats wrong
I am having problem even when connected through ethernet...same D-Link router....browsing on desktop becomes dead slow but wifi works fine on the smartphone.
@alagiri @CutestDevil try setting the channel width as 20 MHZ under wireless setup and see if that helps
Thanks bro,just set it up according to what you have told,so far working without any dns error atleast,let me explain you how it works fine for me for long, though i eventually get ended up with error after half and error but not frequent.. i select wifi mode as B,G only and set channel to 9 then i face no such issue and it goes fine for long..if i select bgn,and channel to auto,or anything,i end up getting dns resolve error after like 5-10 mins,it fails to work completely,i have to disconnect and reconnect it again using computer like normal from wifi networks list selection then it again starts to work normally as if nothing was happened..i dont know what its wrong here,my computer or airtel router,when i check status of connection in router,i see some
UAS errors and Up Stream FEC Errors
..i face no issues at all in using it in mobile,just only in computer and there was no such issue in my old bgn based adsl router
Hey guys can anyone check if port 80 and 5000 is NOT blocked on airtel by forwarding. I can't get it to work in dsl 224.
Can someone check on their diffrent routers provided by airtel
