Are You Suffering From Internet Connection Problems From June 1 ?
  • Thread starter Thread starter vmsanandh
  • Replies Replies 35
  • Views Views 7,660
vmsanandh
BSNL Broadband
Dear Friends ,
Im from Sivakasi .
From June 1 onwards , im experiencing internet connection problems . I have connections in my home and office . Both connections have problems . When enquired my friends throughout TN , most of them are saying that they are having the same problem .
The problem is , Net is connecting but it takes more than 5 minutes for 1 page to load . And also the LINK light goes off frequently and hence disconnection is frequent . Most of my friends throughout TN are experinencing those problems .
I contacted BSNL office . They are saying silly reasons that my phone pin is not properly inserted and so on . When i said them that most of my friends are having the problems , they are saying that there are no problems from BSNL side .
I cant believe them . Surely , there is some big problem in BSNL side .
How many of you are experiencing such problems in TN for the past 3 days ?
I am from Chennai(Tambaram). Me too having the similar problem. It used to be lot better earlier. When I see the log in portal it shows frequent/automatic connections/disconnections every three minutes.. There must be some problem in the system..
members/sathish_tom/@/members/draog//members/vmsanandh/ i could confirm working Ok in Chennai. You can also try DNS change. working on old Dataone since 0430PMWhich is the modem you are using ? Post device status page ( screen shot) and change mod to GDMT Change to OpenDNS 208.67.220.220 and 208.67.222.222( Start/Network/Lan/ Properties/ TCP/IP properties )
@/members/draog/
1. My modem is Huawei DSL Router
2. The connection appears to be ok/better now. Do you suggest us to switch to Open DNS anyway?
3. Modem status appears to be better now. In the morning, the numbers were wors.... and the status used to change often among 'connected' , 'connecting' and 'disconnected..
if you experience slow browsing speed but fast download speeds then its normally a DNS issue and as essbebe said switching to opendns can help
well i've been experiencing simmilar problems since 15 days now... i use open dns.. but at times .. no manytimes some sites dont open.. usually google.. hotmail.. xtremesystems... etc etc .. i've to reconnect the connection to make them open.. and yeah when i re connect it gives error 718 or sometimes connecting to wan miniport ... even thou the snr values are 30 +
Dear friend i am from rajasthan i am having similar problem there is no link at 5am than again the link come at 7pm so for the full whole net does not work its continuing for last 3 or 4 days:wall::mad::evil::redface:Dear Friends ,
Im from Sivakasi .
