Are You Suffering From Internet Connection Problems From June 1 ?
  • Thread starter Thread starter vmsanandh
  • Replies Replies 35
  • Views Views 7,660
tried an alternative browser?
Yup, tried everything. Changing browser, changing DNS and what not. Few of my friends from Pune also said that websites are not opening fast. It's kinda slow. Don'n know what's BSNL is up to. :S
Edit: Can it be some PORT problem? Experts kindly give opinions.
@iChaitanya I had experienced something similar in bangalore around 2 weeks back.Where even my friends had this slow browsing speed..its mostly bsnl's fault.It looks alright now...
:@/members/ichaitanya/
Presume , suddenly only you have problems.
And tried everything including an alternate browser. ( say Opera or FireFox)
Your speed 256Kbps for Home 750 plan.
Needed:P :Post speed details from speedtest.net for servers in Mumbai and say Melbourne.
Suggestion1.:D Download Anvirtask Manager. and Monitor your system.
Needed: P:P:Post Device status of your modem showing SNR/Attn etc.
Suggestion 2: OS updated ?
Suggestion 3: Delete all old System Restore points.
Suggestion 4 : Use Advanced WindowsCare personal or pro from www. iobit .com
Para two : With 123 posts so far, the info you have given is very hazy.
For Instance changing DNS and what not
does not mean you tried OpenDNS.
Dear Friends ,
Im from Sivakasi .
From June 1 onwards , im experiencing internet connection problems . I have connections in my home and office . Both connections have problems . When enquired my friends throughout TN , most of them are saying that they are having the same problem .
The problem is , Net is connecting but it takes more than 5 minutes for 1 page to load . And also the LINK light goes off frequently and hence disconnection is frequent . Most of my friends throughout TN are experinencing those problems .
I contacted BSNL office . They are saying silly reasons that my phone pin is not properly inserted and so on . When i said them that most of my friends are having the problems , they are saying that there are no problems from BSNL side .
I cant believe them . Surely , there is some big problem in BSNL side .
How many of you are experiencing such problems in TN for the past 3 days ?
I am from Sivakasi too... It worked fine for me on June 1st but after that I left to Chennai. I don't know if anything happened after that... but on the first day of the month I was downloading all stuff at reasonably good speeds and without disconnections. I'll check it the next time I go home and tell you
Needed most speed details from speedtest.net for servers in Mumbai and say Melbourne.
Suggestion1. Download Anvirtask Manager. and Monitor your system.
Needed: Post Device status of your modem showing SNR/Attn etc.
For Instance does not mean you tried OpenDNS.
Mumbai Server:
Melbourne Server: :wall:
NYC Server: :wall:
Have a look at those ping times. What can I do to reduce those ping times?
I am using Kaspersky Antivirus 2009 and I am very sure that there aren't viruses in my system.
UTStarcom UT300R2U ADSL Status (I was not connected to the internet when the screenshot was taken):
http://img76.imageshack.us/my.php?image=capturebd5.jpg
Is the modem faulty?
I am using XP SP3 and Vista SP1. Websites are opening very slow in both XP and Vista as well. Deleted all restore points, but no difference in loading times. As i have said earlier, I am getting good download speeds but websites takes ages to load. Is this because of high ping time? :( And yes, I have used OpenDNS too but still the problem persists.
update:I am getting good download speeds but websites takes ages toload.
256Kbps tariff plan @members/ichaitanya/
Option1 :You are referred to Dr TCP for second opinion ! MTU to be set to 1492 or 1480 etc
Download DrTCP 0.21 - DR TCP - a internet speed connection optimizer. - Softpedia
Vista OS. Will look for another expert ! ( Do not use above program in VISTA)
Option 2 :. Your SNR 8.4 is bare minimum. Check Rj11 cables for oxidisation/corrosion/
Change to new cables. No phones BEFORE the ADSL splitter. If not possible use additional ADSL spliter for PHONE/s only.
Change mod to to GDMT and report +ve or ve result.
Option 3 : Did you try suggestion 4 in Post 28 AWC personal.
.............. use all options. In Start up menu keep programs to minimum.
Option 4 : Download Opera Browser . Or FireFox.( Post 21 @sushubh)
Option 5 : Disable IPV6 in Vista TCP/IP properties.
Para two : Addl Info required
A: Confirm you are using Dual boot in same computer .Try all with XP Sp3. feedback
i talked to bsnl officers in various areas of bangalore as mentioned in evdo post..well here in bangalore they aren't even givin landlines in some areas fr the last 2weeks...my landline has been postponed by 2 months and dataone by 3-4 months!!!!!!!!yes there is some prob regarding bsnl but i din know it's also outside karnataka!
